Andrew1014
I'll try to explain in full detail as well as I can. I have a small (maybe 10-12 inches) electric RC Heli. It worked 100% when I first flew it, a table jumped out of no where and attacked my heli. Now it vibrates, it didn;t atatck my heli too hard or anything.
Here is what happens. When I hold it in my hand by the end I fire her up no vibrations at all from stop to a quarter throttle, it floats fine, when I go to half throttle to take off it will vibrate a little bit, and the vibrations cause it to lose power. but if I give it full power the vibration goes away....?
In flight if it starts to vibrate I notice it falls, if I turn it (gyrate? Idk the word, it spins without moving forward or backwords) the vibration stops and it shoots right into the sky or ceiling wherever I am.
I checked the blades their not loose, or tight. the gyro on top is tight... wings aren't marked up... in the mast? (the bar that holds the wings) I noticed if I pull and push on it very lightly there is some slight play. maybe that is it? I don't want to tinker and break it not knowing what I am doing...
Please, Please help me...
Thank you,
Andrew.
Thank you,
Andrew.
