Punisher
RCTalk Qualifier
Hi all,
I recently fitted a GO 21 GX 5R to my Losi 8ight Truggy.
I spent most of the last race meet trying to tune out a lean bog on acceleration - I had a bugger of a time tuning out the lean bog . . . in fact, the engine won, I never really got it running right all race meet - VERY frustrating!
After a bit of research I have learned that the GO engines are fitted with a long needle carb . . .
After some more research I found some info detailing how to tune the long needle carb - basically backwards to the short needle . .
- pinch test to set the idle gap and LSN
- tune the HSN
- fine tune the LSN
Apparently if it develops a rich bog on the LS, lean the LSN - easy.
But if it develops a lean bog (as I have been experiencing) it is recommended to add the fuel via the HSN NOT the LSN.
What is frustrating, is that the LSN and HSN on a long needle carb are very closely connected; any tiny adjustment to the HSN (and I do mean tiny) has a dramatic affect on the low speed tune.
I'm finding that I am chasing my tail.
The plug looks ok – HS performance is excellent – but it runs really cool – Temps are only 150F
To increase the running temps I try lean out the HSN . . . . and it develops a lean bog!
Also, when leaning the HSN, I am take the needle far away from the stock setting which I understand should not be required (ie considerably under level) - and of course any tiny adjustment to the HSN has a huge affect on the LSN . . .
- lean the HSN = develops a acceleration bog
- richen the LSN = lowers the idle speed – wont idle (does that mean my idle gap is too small?)
- increase the size of the idle gap – richens the LS!
** I just keep going around and around.
Does anyone have experience tuning these carbs? Can you provide some advice/useful tips?
I understand the long needle carbs are good on fuel economy and deliver a nice fuel curve – I would prefer how to learn how to tune it and make it work, but I can't really afford to wrestle with an engine and it's tune when racing.
If you can't help me with my tune, can you tell me which short needle carb will fit a Go .21 - I would entertain removing the long needle carb and keep it for another day when I want a challenge.
Thanks in advance for your help.
- tune the HSN
- fine tune the LSN
In real life when you "Hit the track and tune the hsn." . . . it's not a fine tune adjustment required - a very small adjustment to the HSN dramatically affects the LSN. .5/12 on the HS will give you a lean bog! . . .
