Zaytri
Hello!
Been a member and been readin for a while now, and it's clear lots of you have TONS of experience, so that means you can help me out! Right?
First, the tuning problems...
Engine is a OS .18 CVRX -- I broke her in with about 6 tanks, and it MAYBE has 3/4 of a gallon on it. Lots of compression. Starts with 1-2 pulls, and runs GREAT, but only in the 200-220 range. As soon as I hit 250ish, it seems like the fuel is burning off in the carb before it gets into the engine. If I'm not going WOT (as in driving around slowly or idling) the engine will pulse in RPMs until it shuts down, at which point it will not start until it's cooled off. <Hissing sound comes from carb when i try to prime it> I think 200-220 is a good temp range, but it seems the car is underpowered and wants more, but I'm not quite sure!
Steering - Will be perfect for about 5 mins, then out of nowhere, car will constantly veer to the right. I'll change the trim, and it'll run for another 5-10 mins, at which point it'll veer to the left, and ill have to change the trim again.. :shrug:
I purchased aluminum towers as you can see in the pic, and upgraded to hard springs on all wheels, and I'm using newly rebuildt 40WT oil all around. Since the aluminun upgrade, i seem to end up on my lid ALOT more. Any kind of bumpy grass or dirt at any decent speed will send the truck flailing off the ground and onto it's top. None of the shocks are binding, and they move freely in all directions <up and down > I'm not experienced at telling when tires need to be replaced, could that be the problem?
And now, the mechanical ones! Yippee!!
Servo Horns... Who/Where can i get decent servo horns? My LHS sucks when it comes to their selection.. And the owner is a real bum for ordering stuff that isnt in demand.
Throttle Linkage... As you can CLEARLY see in the pics, my throttle/brake system is in a state of supreme ghetto rigging. Since the engine upgrade to a slide carb, I'm having trouble getting a good system in place to work the gas/brake. The linkage kit from HPI only supports rotary carbs. Anyone have experience with this? I want a throttle return spring as well, but dont know where to start in it's application and placement.
Header/Pipe... I cannot for the life of me keep the stupid pipe on the truck. BY tank 2 or 3, it vibrates off causing anyone within a 1/4 mile to know my exact location :arrr: Is there a better quality header i can purchase and put on without crazy mods? What's a good pipe for general bashing? Is there a better way to secure the pipe then the cheap plastic arm that attaches to the chassis? AHHH!
And for my own to anyone who owns this truck and wants some personal experience feedback..
The upgraded chassis RULES!! It stiffens the truck out IMMENSELY. Hi-Torque steering servo makes a GIGANTIC difference on handling. Titanium turnbuckles can bend, it's cheaper and easier to use the plastic ones or make your own. Shim the diffs if you upgrade the motor.. I learned the hard way. Slipper clutch upgrades helps control on dirt ALOT. Upgraded hinge pins and have never had a problem since! Upgrade your shock springs ASAP!!!
Final question..
Has anyone seen a roll-cage for this truck for under 100$?
Thanks in advance for any/all feedback and answers!
You guys are great!
Andrew
P.S. Could someone PM me on how to add pics to the actual message? Pics will be linked as soon as Webshots stops being grumpy.
Final question..
You guys are great!
Andrew
