Traxxas Revo 3.3 engine dreams
rcaddict234
I’ve been dreaming (like all RC hobbyists do). if I were to get a bigger more powerful engine for my Traxxas Revo 3.3 (possibly no longer 3.3) what engines would fit and what is the best quality and most powerful engine out there that would fit the original truck? Thanks ahead of time.
I could be mistaken as I dont own that rig but I believe the O.S. .21TM is a direct drop in. I believe they also make a big block conversion for the REVO at which point Id put a .28 or .30 in it. Probably a HoBao Hyper or LRP brand
The OS .21TM is a direct drop in BUT it has the same power as the Stock TRX 3.3 Engine...
The OS .21TM definitely is a much better quality Engine!!
I have both these engines...
So I'm speaking from experience and with the OS Engine you will definitely have less headaches!!! JUST AN EXTREMELY EXPENSIVE UPGRADE!!!
Hope this helps...
From what I have read online, you put anything bigger on a Revo and your diffs will suffer, and is another very very expensive upgrade.
The other option would be to upgrade the 3.3 with a Sirio crank (rare), stronger con rod and a OS 11K carb but unless those parts are found cheaply it ain’t worth it. OS engines are worth the money.
mattyice
Replies
15
2K
tudordewolf
tudordewolf
R
Replies
3
2K
tudordewolf
tudordewolf
2010450X
Replies
3
TMAXX
TMAXX
R
Replies
3
Greywolf74
Greywolf74
