Toki .15 - strange engine, no sleeve!
tudordewolf
Being a sucker for cheap and strange nitro engines, I had to buy a Toki .15
There's videos of them running, and they've been discussed on the forum a few times, but I can't find much more than that about them. They seem popular for those janky little DC generator "kits" which I assume only exist to win science fairs.
The first thing I noticed was the unusual construction - the carb is screwed down instead of using a pinch bolt, and the crankcase splits in two at the cylinder, held on with only 3 bolts. Pulling it off revealed stranger differences: it has no piston liner! The cooling head, button, and piston are all a single piece of machined aluminum, unless they somehow nickel- or chrome-plated it on the inside. The piston appears to be brass, as does the connecting rod, but I don't know if that'd even survive, maybe some aluminum alloy. So instead of ABC or ABN, it's BA - brass piston in an unlined (?) aluminum piston.
Probably gets pretty great cooling, though.
View attachment 153111View attachment 153112
Did you already get it running??
I sold it, I realized I had too many project ideas that I'd rather work on first. They're pretty readily available for ~$50, but for that price point you can get a VX-18 that'll be better for most applications.
There's videos of them running on YouTube though, seems like a normal enough nitro engine. 17k RPM redline in the manual and it advertised ~1kg of pull with a 9x4 prop I think.
I learned what vehicle this was used in, the Hasbro Ricochet XRC and Revolution MT, basically toy-grade nitros, kind of a cool idea that flopped.
I am very curious how long they keep compression though, once they lose pinch it seems that's it for the engine.
