Good Day, Party People
I never really made the conscientious decision to start modifying my Revo, and I really wouldn't expect this to become some crazy big block one off build with crazy rare and old school parts. This is just going to be my un-comprehensive build post for a relatively simple and standard Revo build. Basically just something I can work on and look back on if I need to reference something, feel free to follow along with me as I go through and build this thing. I'm not shooting for speed or durability, my driving is pretty tame and I think this thing is plenty quick as it is.
Currently Installed Mods:
- Swapped Over to a ELRS Receiver
- Deleted Opti-Drive
- Forward Only Conversion
- EZ Start Glow Igniter Removal
Planned Modifications (subject to change with time):
- OS11kr Carburetor (These are on backorder until July, unless I find someone who has one laying around this will have to wait)
- Swap over to an OS21??? (We will see about this one, it's expensive and I might just be happy enough with the 3.3 and a carb upgrade)
- Potentially a roll cage?
- Once I finally break an Arm I'll replace with RPM
- Stainless Hardware
- I would like to change the wheels that are currently on it for a different design, but the stock tires have held up really well even after a couple gallons
- Swap over to a single steering servo (Unsure which one to swap to)
So I've been wanting to start this thread for a while, more so for my own desire to just sit down and write for a little bit about my favorite rig, but I haven't really turned a wrench on this thing since I've had it outside of basic maintenance and a thrown clutch spring. Well, I finally decided to start tinkering with it a bit these past couple of weeks after purchasing a new transmitter and wanting to swap over my vehicles to said transmitter. The first rig in the hot seat was naturally my Revo, as it's my favorite in the stable and the one I use the most frequently outside of everything else. After receiving my Radiomaster MT12 I realized that I was going to need more than a 3 channel receiver if I wanted to get that Transmitter working with the rig. So I took to Amazon and ordered a Radiomaster ER5C 5 channel receiver. Of course, as I waited for my new receiver I took the Revo out only to realize I was having some hiccups with Reverse anyways - back to the internet to order a FOC for it. I had told myself the second I realized any issues with the opti drive system I was just going to pull it anyways, so naturally I did just that.
So, preemptively I started ripping everything out. The Opti Drive Sensor, now spare linkages and servo, and started cleaning up the wiring a little bit. During this process I decided I might as well just remove everything and give it a good once over.
Now, naturally this got out of hand. Many toothbrushes, and more degreaser than was actually needed has gotten us here. But it cleaned up well. I removed all of the extra sensors that would have otherwise gone to the now removed Traxxas TSM Receiver. A temp sensor, and speed sensor. I might as well mention that I had a wonky EZ-Start Glow Ignitor wire a few months back. So I have de-pinned that plug and completely removed the wire and swapped over to a traditional glow plug igniter. I really want to get rid of the remaining 3 wires for the EZ-Start system next, but I'm not fully sold on the idea of going over to a pull starter for this thing, I like being spoiled by the ease of use of it, not gonna lie. But having one less thing to lug around when I take this out would be a big plus so who knows?
During my obsessive cleaning spree I decided to go ahead and pull the carb off and clean it out, not a true rebuild as I replaced nothing. But cleaning out the needle jets and O-Rings I figured it couldn't do any damage. I'm still pretty sure that most of my runaways (cause I have a lot of them) are mechanical ones, I think my slide carb is getting stuck at WOT. Maybe I need to replace my throttle servo too....we all know Traxxas Servos are less than stellar anyways.
I didn't take a ton of pictures of the Carb rebuild - just a reference photo for when I put the thing back together.
Finally Some Mail!!!
Which was good timing as I had just re-installed the engine and was waiting for this and my ER5C Receiver (Which I also received in this shipment) so I yanked the transmission out too and cracked it open, which was surprisingly difficult and it fought me the entire time. I found this bent copper washer as the culprit. It's left me wondering if this is the reason why my transmission was giving me issues, or if I just broke things with my tiny ape brain. Who knows? I sure don't.
Deleted Opti-Drive For your Viewing pleasure.
And well, I followed the relatively vague, yet helpful instructions as best as I could. And you really do remove a ton of rotational mass from this thing going over to only forward gears. No need for a shift fork, and for whatever reason the reverse gears are metal, while all the drive gears are plastic. Which really makes a ton of sense to me - not. Well, everything still went back together without much of any issue or drama. I will say that it's nice that with this kit you get 3 really nice different block off plates. A plug for the now MIA shift fork, a plate for the Optidrive sensor on the transmission and a blank plate for the now open bay that would otherwise house the Opti-Drive unit itself. It really cleans up the look of the chassis.
And my ELRS 5 Channel receiver got installed!
Now, I'm not going to sit here and pretend I know everything about switching over to Radiomaster or ELRS. But the quick rundown is, it's tech from the FPV world with really good penetration (hence, no antenna) and it's all open source goodness. I haven't really dived into ELRS itself yet, but the receiver itself has it's own Wi-Fi chip and can do firmware updates through your home WAN. Which is pretty neat, I plan on tinkering with it a bit today. EdgeTX I have messed with a pretty good amount though and I built a setup for the Revo which definitely is still a work in progress. I've just been a bit distracted by my kids these past few days and haven't really gotten to finish up a few settings.
Enjoy the Jank picture. But, yeah. Quick run down on EdgeTX itself. It's another piece of software that's also open source and receives pretty frequent updates (relatively infrequent in terms of relevancy to us surface user plebians). A lot of people say EdgeTX has a bit of a learning curve, and although I think there is quite a bit of truth to that, I'm still getting the hang of it myself I don't think the learning curve is any more than it would be if you where to swap over to a completely new radio system regardless of brand as there is going to be a relearning process for a Sanwa, FlySky, Futaba, Spektrum you name it. The cool thing is, if you can think it you can do it with EdgeTX. Learning the how, and the syntax that's built in the system is where people tend to throw that stuff around but it's relatively easy if you tinker with it for a bit. I have a timer set for my fuel, managed to clone my CH.2 Steering Servo with my CH.3 Steering Servo (I don't have a way to make a Y-Harness at the moment and didn't buy one) I have a raise idle button, and two failsafes setup, one I engage myself and another if the receiver loses connection. Perfect for a 40mph 15lb Nitro Monster truck that isn't perturbed by the ground underneath it's feet! The ability to adjust the springs on the steering and throttle on the actual transmitter itself is real cool too, did I mention it has games built in? Its Gimmicky as all hell but my kids thought it was neat.
First Run with Forward Only and New TX/RX Combo
Outside of my Alignment being slightly out of whack now, which was a simple fix, the Revo started easier than it's ever started. I think the carb needed to be torn apart and cleaned since the beginning of time this entire time. Even on a pretty old Chinesium Glowplug it's running great - rich as all hell - but great. Tearing the transmission apart must have caused some adjustments to the shift point, it really doesn't seem too keen to shift, but it will. I need to spend some more time tinkering with it, hopefully I will get a chance to today and if not today I definitely will throughout the week at some point. It has quite a bit more go, it is noticeably more willing to get up and go, even with my lower nitro% fuel, does wheelies, and pisses off like idk what. I really enjoy it.
I only really got to rip it for about 15 minutes so far, most of which was idling. But the new transmitter seems super nice. Which I am excited to use more. My gas timer is a bit messed up but I can fix that with a little bit more tinkering. I'll keep you all up to date on that side of life. I think the next mod I'm going to do is swap over to a single steering servo, really don't want to buy the Traxxas recommended one - if anyone has a suggestion let me know. I would like to get rid of the redundancy, and it just seems like a hell of a failure point - and a pricey one at that.
Now I need to figure out what to do with all of these controllers and my other E-Waste
