big jilm
I got the revo all charged up for a good day of bashing and all well broke loose!!!
First- I turned it on this morning and noticed that the servo that controls forward and reverse was acting up. The car wont go in reverse..So I say screw it, it will give me something to fix later.
Well, I get the car warmed up and notice that it wont sit still. Without throtl it is still moving pretty quick.Then the reverse kicks in and doesn't wont to stop.
Well the car ends up dying and wont start. the ez start says the glowplug is bad so I change it and tried to start it. doesn't wont to start and then stops turning over. I pulled the plug thinking the engine was flooded but nothing. I put it back together and it turns over a couple of times and stops again.
I've pulled the plug and tried to drain the engine about 4 times now and it still turns over a coupl of times then stops.
So- I think the servo is shot and the ez start motor apears to be dying.
I looked into the engine when I used the starter and the piston will move but even with the glowplug out it still seems slower turning over than before.
Got any ideas??? Could a bad glowplug make the engine stop turning over???
