darnoced
RCTalk Champion
Just a couple of pics of my T-maxx.
When I got it it was pretty well a basket case. Nothing worked.
Now at least it runs.
steel roll cage, hd aluminum chassis brace, titanium center skid, titanium steering connector, aluminum rear bulkhead (front one enroute), imex 17mm hub rims, maxx dawg tires, double filter air cleaner, 20 tooth pinion gear, 72 tooth RR steel spur, hd diff gears, one RPM a-arm set(lhs only had the one), 2075 steering servo, aluminum throttle post, and 2055 throttle servo.
My problem is that I can tune it to run great with the body off. As soon as I put the body on it overheats. I've tried to richen the HS to compensate with no luck and cut holes front and rear for airflow. Is there something that I am missing, or do I have to cut more holes...or what??
