ChiefGeek
Military Veteran
So I replaced my clutch bell when it was stripped. I'm still hearing some grinding or something when I get on the throttle. It only made this sound when the wheels were onthe ground. When held up I can go through all 3 gears with no issue. So I tore it apart again. The clutch bell shows noticable wear and has only been ran a couple times. I have a metal spur so I'm going to replace it with a nylon. I looked into the oil holes on the transmission case and the 3 gears I could see look fine. Where else should I be looking while I have this thing apart to ensure I remedy the problem?
Next question, slipper clutch. Something I read say tighten all the way then back off a quarter turn, but this doesn't seem like a good way of getting proper tension. Another said tighten a little at a time until I can no longer tighten by hand. Any suggestions?
