Piston
I was out with the truck today and noticed a wierd problem starting up. When I land the truck of a 3ft jump and it hits a bumper or on its top, the engine will die. It immediatly restarts with no trouble and takes right off as if nothing ever happened. I assume its the jolt affecting the piston/rod movement for a split second causing it to stop?
It dies the exact same time it hits the ground... I wonder if the engine is getting a little low on compression and its just not a strong idle, I dunno. It does seem to happen more when I'm not on the gas as it lands.
Glow plug is new and lighting up as it should, this was my first thought since I was having a hard starting issue too. I replaced the glow plug and cured the starting problem but the dying problem is still there.
