Maxxcrazy88
Ok I've about had it with My 2.5...
I run it for the first 1/4 tank and it runs fine but when I hit 3/4 and it will bog down at Idle and Die( Idle is at the point where it lurches badly)...... I had it running good but then I Drilled out the pipe (stock pipe) and I richened it up some and It started doing it again.. I have tried to tune it so It doesn't die but it still wont quit dying at idle (no matter if I richen it up or lean it out)....
I have also noticed tons of nitro grime on my Chassis by the back of the engine So I am thinking it might be an air leak... Does this conslusion sound plausable(sp?)???????
and If I have to what kind of silicone would be best to use to seal it????
