On my stampede 4x4 when i put it on the ground and give it throttle it mqkes a real loud screeching noise coming from the rear of tue truck and it hardly moves
Okay i took the whole rear end apart and didnt find any wear i accidentally losened the slipper clutch all the way so it would make a scream noise but when i tightened it then losened it a 3/4 turn lose it still made the noise but it fixed itself after doing a long wheelie to likr 3 flips but after i was done running i touched tje motor and i burned my finger is that normal for lipos?
Re-set the gear mesh by putting a piece of paper between the spur and pinion gear, push the motor against the spur gear and tighten it down. When you pull the paper out it should have a zig-zag pattern with no rips.
Another question: how do you half charge a lipo battery for non use i have a hyperion EOS0606i and I'm usin a turnigy 5000mAh 3s lipo and a 7.4v 2s 5000mAh how do i ready these for storage.
Expect to replace that motor before too long. If it got that hot, it probably won't last much longer. The idea of gear mesh is to get as much contact between the teeth as possible without any binding or tight spots.
