I just push the motor up to the spur gear and back it off just a hair. I then tighten the motor mount screws down just enough so that the motor wont move. Then I hold the clutch bell with my hex driver and move the spur gear on the clutch bell. If you can't hear a very slight "clicking" between the CB and spur gear, you are probably too tight, and if you can see too much play between the 2, probably too loose. Once you have it where you think it is good, put some loctite on the motor mount screws and tighten them down now, then test it with the strip of paper to see if you get those nice unifrom teeth marks in the paper. Remember, when you pull the paper out with your needle nose, if there are no marks on the paper, too loose and if the paper rips when trying to remove it, too tight. it can be a pretty finicky process until you get the hang of it.
[ame="http://www.youtube.com/watch?v=73xlmyk0K_U"]MVI 5493 - YouTube[/ame]
