I have about 3 cars. Do I have to buy 3 receivers so I can use the same radio? OR can I take out the rx each time I use a car?
You can move em....but its a hassle as you will have to re wire each time and build different models for each servo set.
The cost the DSMs is pretty cheap.....ebay is a good source, I picked up three myself and have been happy with them.
You may still need to set up different models on the radio if your servos are not the same orientation (some servos see direction backwards). An example is JR and Hitec....they work in opposite directions.......so you have to tweak the radio each time you switch between rigs....the spektrum makes that easy to do...and also will allow you switch set ups on the fly with the programmable models.
Ok I have exposed enough of my ignorance on the subject....somebody else jump in.
Later
Talon
