Is yours the 8ight, or the mini 8ight? Looking up that ESC, it comes up as being for the mini 8ight. Whichever one you have, you dont have to have the original ESC if yours is bad. You can easily replace it, and, pretty much any newer ESC will be an upgrade as well. If yours is the mini 8ight, then, pretty much any 1/14TH or 1/12TH scale ESC should work, and, if it is the 8ight, then pretty much any 100A or larger 1/10TH or 1/8TH esc should work. The only thing you will want to make sure of is that the bullets for the motor are the same size, or you will have to solder new bullets either on the motor or the ESC so that it will connect.Hi anybody got a spare or wants to sell as an original speed controller MSC-18BdLHP for losi 8ight buggy thanks
The Hobbywing 16BL30 is usually a good choice as is the 10BL60-SD. If you have money burning a hole in your pocket you can always get the Castle Mamba Micro X2.theres a few brushless mini esc out there .I wont post a discontinued esc..op you can go up in amps wont hurt anything,
