bigben
Evening everyone, I am not sure if I should have attached this to the previous thread or not, but I will start a new one anyway. Well, I got my car and finaly got around to running it today. (Well sort of) It took me forever to get it running (ended up paying a kid at a hobby shop 20 to tell me I had flooded the engine) Nerveless I finally got it running for 1 take of gas. (Although I swear I ran an entire tank of fuel through it by hand cranking the engine) I ran into a few things and I am hoping I can ask all of you for your suggestions.
1) When running the car moved around great at first. Then it just stopped moving forward. The engine was running fine, the gears along side the engine (Sorry for not knowing the technical terms) were spinning when I gave the engine some gas. The half shafts err dog bones were spinning but the tires would not. The rims did not appear to be spinning (thinking the glue broke loose). When I lifted the back end of the engine off the ground the tires would begin to spin. Could you possible recommend any resolutions?
2) The front tires seem to point to one side. When I turn on the receiver and transmitter, the front tires angle towards the right slightly. Can this be fixed by shortening or lengthening the connecting rod from the server to the steering arm?
3) To rich or too lean. I have been given 4 different ways of breaking the engine it by for different people. I think I will stick to the 5 fuel tanks turning the fuel back a little at a time. I followed those directions and tested the cylinder head by dropping a drop of water on the head to see if it will evaporate and it was not evaporating. However, I am wondering about the color of the exhaust smoke. When idling the there is no smoke at all. However as I added a tiny bit of fuel it began to smoke blue slightly. Is there supposed to be any smoke? If so, what color and when? Any input you can give me on this I would very appreciative to know.
4) Best way to hold the body down when starting? I seem to have to push it all the way to the ground to be able to pull start the engine. Is it o.k. to bottom out the body and hold it down to start it?
Well, I am sorry to ask all the questions, but I am really excited about my first nitro car. I thank you all for taking the time to share your knowledge and experience.
Thank you,
Ben
One more quick question. What kinds of surfaces is it safe to run a car on? I know dirt, grass, and pavement are o.k. Is sand o.k.?I do not mean the beach but more like lower New Jersey were the ground is mostly made up of a hard packed sand. I am not sure how the car would handle in sand. Thank you again.
Ben
Thank you,
Ben
Ben
