- Alexandria, VA
- Crawling
- Flying
SOLD
Just realized this thread is still active. I want to send these wheels to a good home. $55 shipped to the lower 48. Anyone who knows the retail cost of this set knows this is a helluva deal
Currently building a Vanquish VRD Carbon and purchased these SSD's for it but opted for something else...Anyway, the set is brand new. Specs are listed below. $75 for the set of four shipped to the lower 48. Hit me up if you have any questions.
CNC machined aluminum
Bronze anodizing
Standard 1.9" wheel size
Standard 12mm hex mount
Also fits Axial 12mm hex
Internal beadlock system
Removable hub
Compatible with SSD brake rotor hubs
Compatible with SSD wheel weights
Compatible with Vanquish SLW hubs
Specially made scale steel hex head bolts with yellow zinc plating
Easy to mount tire, only 6 screws
Fits all tire brands
SPECIFICATIONS
Width: 25.5mm
Offset: 0.75mm
Backspacing: 14mm
Weight: 72g
Bronze anodizing
Removable hub
SPECIFICATIONS
Width: 25.5mm
Offset: 0.75mm
Backspacing: 14mm
Weight: 72g
