Kris407
When i finally got to run her after getting the pipe Oring things seemed to be much better. She fired right up and was idling good at factory settings, so i ran a couple laps and she stalled a couple times. i figured from being rich but she fired right up and seemed to be responding good to a couple needle adjustments.. but.. after that she began stalling when i would brake and so i checked the carb gap and it was fine and not closing when i was on the brake but i just could not get rid of the high idle rpms no matter what setting i tried. so being frustrated i quit and went home and when i pulled the engine out i found the clutch spring had broken so that explains one aspect of the whhels turning at idle but how the hell can this thing be at half throttle when the carb gap is at 1mm? it has to be sucking air from the carb, right!?!? oh yeah and check out how crappy my throttle and brake settings are! i have got to figure the linkage out but i admit it i have no idea where to start
anyways i posted a video about my front hub carriers being stiff so any advice on that would be good.. thank you.
broken clutch
broken clutch
