I run 45 weight. Either or will work fine. It improves the vehicles handling greately. Moving the front lower shock mounts out to the outside hole helps, as does increasing a little preload.
70 wt in front with the one hole piston, 40 weight in rear with stock 2 hole piston. Move the lower shock mounts to the outermost positions. Work great for me on the track and when bashing.
