Slash dif question HELP
Suicide
Gone - bye bye.
Whats the best way to make the limited slip in the slash has less slip
Suicide
Gone - bye bye.
the limited slip in the DIFFERENTIAL
reighard53
RCNT Champion
south jordan
ooooooh sorry lol what do you mean by limited slip? sorry I'm not to bright when it comes to some of this stuff
Suicide
Gone - bye bye.
it's okay i thought was kinda obvious in the title. the limited slip lets one wheel go slower than the other. my diff is so louse that if you go on 2 wheels. the wheel in the air spins while the wheel on the ground dosen't. I'm trying to fix that
reighard53
RCNT Champion
south jordan
o i dont know how to do that...did you buy a limited slip diff or is it stock
MGT8.0owner
Hardcore RCNT User
thunder bay ontario canada
  1. Racing
put a heavier weight diff oil/grease in the diff i'm not sure wats stock in a slash but try putting a heavier weight oil/grease in it and it should hold it a little titer
godale03
Awesomer!! Than Rolex!!
Maryland
The stock diff in the Slash is unsealed and filled with grease. There is a mod in XRC on how to seal the diff and fill it with Silicone. If I understand what you are asking, you would need to find a way to lock the diff. You can do this a couple of ways... some folks just put really heavy diff oil to help it slip a bit less... which would require you to seal the diff....some folks actually use JB weld to stop the gears from moving. If you don't mind me asking.. why do you want to stop the diff from slipping?
Suicide
Gone - bye bye.
you get into something where it slips and you have no traction it just spins. i don't wanna totaly lock it i just want it where when you go on 2 wheels you actually have traction
S
Replies
3
HeavyBag
HeavyBag
T
Replies
Tincher32-VXL
T
