Servo fitting help
Laurent James
I had a wltoys l959 4 yrs ago
tge servo is messed up and I wanna change it to the servo shown
First pic is stock
sec pic casing
3rd is servo i want to fit..
are you just trying to use a servo you have already.. this is a 1/12 scale rc.. I dont see you being able to use that said servo.. get dimension's of old servo and look at some on amazon I'm sure you can find one for less than $20..
wait it fits just need to get new servo arms
if you need servo horns the get main get size that the teeth it has then order that size servo horn..many universal servo horn kits more than likely your lhs has some or ask a friend thats in rc.
as for mounts I make my own.
I have one lying around from my e10 drift I could use that. also the servo i wanted was also from the e10?
do be aware though, the 3 wire vs the 5 wire (stock), you will probably need to use a hobby grade Rx/Tx to be able to use the servo (unless you already have one and i just missed it )
D
Replies
4
tntpoof
tntpoof
X
Replies
9
xxtcrageless
X
L
Replies
20
1K
LosiFan143
L
thatcraig
Replies
4
thatcraig
thatcraig
