Just got a new engine, another XTM .18 and cut the crankshaft with dremel, put the flywheel and clutch nut on. Now seems I didn't cut the shaft short enough (needs at least another 1mm) since it doesn't lock the flywheel- the flywheel spins freely whereas I cannot hold the flywheel when unscrewing the clutch nut. Now my problem is getting the clutch nut off! The guy at my LHS suggests I fill the cylinder up with after run oil and get the nut off with that, I tried it and it STILL turns the engine over. I'm afraid if I get a piston locking device, all that preasure will be making an ugly groove in the brand new piston.
HELP!
HELP!
