Very nice! I am saving my FLM Savage build for the HPI gas conversion, hopefully soon to be released!
heres how i did it. (sorry for blurry pics, camera puked out and had to use ipod)
i cut a stock 2011 engine mount to fit in the area behind motor, and attached a brace and drilled out 2 holes to fot big screws. then i took a black tmaxx rx box and cut exess between screw tabs and bottom(cut flush) then i screwed the base to the plate, installed my switch and Rx and screwed the box to base. drilled to holes in the box to zippy-tie battery to top
i been eyeing an orange aluminum rx box for revo, but no clear answers yet on the dimensions
my problem is that there is enough room between motor and plate for a pullstart, just not a losi pull/spin start, or just a losi pullstart (its too thick)
hard to say...electronics will generally handle a little more than what they are rated for but how much more is not always obvious and running them over their stated rate will probably shorten life span I would guess as it will probably make them run hotter than normal. Something else to take into account is 6.6 Volts (if I understand LiFe packs correctly) is the nominal voltage of the pack. IDk what LiFes max charge rating is since HobbyKing has been taking their sweet @$$ time delivering mine to me but if they are along the same lines as lipos then the max charge will be a lil bit higher than 6.6V probably closer to 7V. IDK, never tried it myself so this is all just my speculation. What i would do to be on the safe side (unless you have cheap servos and RXs that can easily be replaced if damaged) is get a BEC and a couple of really cheap 2S lipos (or you could still use those LiFe packs if they are extras) for like 4 or 5 bucks each and just go that route. Constant 6V input and no worries. Hope this helps.
If your gonna use a BEC then theres no need to use cheaper servos they will be fine on a 6V BEC. If you are running 2 Steering servos Id pick up a 5-6+A BEC. IDK what sevos your running but a good high torque steering servo and a decent spec throttle servo will push a 3A BEC pretty hard. I know a 3A BEC isnt up to set ups with dual high torque steering servos so I'm not 100% sure with that set up there. I usually only use 3A BECs on my lighter electric kits that just have a single steering servo. You could also run each servo on its own 3A BEC but thats kind of a pain to wire up but maybe cheaper as those 3A Hobbywing BECs are really cheap.
The Castle BEC is my BEC of choice but it is a bit pricey. If you have a castle link (the little circuit board that is used to program Castle Speed Controllers then you can program the Castle BEC to output anywhere from something like 3V all the way up to 10 or 11V. can't recall the exact numbers off the top of my head but its highly versatile. Of course if you dont have a Castle Link already then you wont be able to change it but I think (and dont quote me) that it comes by default at 6V. Check with castle or your LHS to be sure. You LHS can probably set it for you also if you dont have a link and never really plan on switching it much after its set up. Otherwise HW makes some 5+A BECs that would work also but alot of them come from overseas so you have to wait a lot of the time.
For a low voltage alarm you'll need something like THIS. You can velcro it to the pack itself and then when you get ready to use it you just plug the balance plug from the lipo into the alarm. I believe most of those cheap chinese ones like I just linked are set to go off at about 3.3V/C which is plenty good for a lipo. Most people usually set the LVC between 3.0 and 3.2V/C anyway.
---------- Post added at 8:44 PM ---------- Previous post was at 8:37 PM ----------
You can get a new Castle 10A BEC on ebay for about 2.15 cheaper than tower hobbies and that includes shipping which I dont believe Tower Hobbies price does. HERE is a link to the cheapest one on eBay.
Been thinking of picking up a couple set's of SPI 3.2 bash wheel's and looking for a little info on proline Masher 3.2" All Terrain Tires.
how well did they hold up on concrete and black top.
I run about 75% time on dirt and gravel 25 % on concrete,black top.
Thank's for your time and info
Looking good! I was wondering what arms are you using? The top arm looks like RPM
