DarkEnergy
After some research, I concluded that the Savage trucks were the funnest and most durable for bashing.
I also knew I wanted to build from parts so I went for the SS kit, which apparently has some better parts and comes in 457948574857 different pieces. Perfect =).
This post isn't meant to inform, moreso it is to share some pics, ask some questions, and generally get a feel for RCNT so I can hopefully leach some knowledge.
I own an Associated RC18T, which I've taken apart several times, and an Aero Ace. Next project will almost definitely be a beginner nitro plane. I am a total noob, PLEASE tell me if I'm doing something wrong.
DAY ONE
Ok, on to the project. I spent a couple hours rearranging so I'd have plenty of space. The room I'm working in is the dining room/office/workshop/guest bedroom.
Here is the box of parts. Left side is bags A-K, and right is injection molding stuff. Not pictured is the engine, two diffs, and the 2 speed tranny... and some other crap.
This thing is HUGEZ. Check out the tire:
Connect shock tower, diff, and alluminum base. Make two of these.
Build suspenstion linkages... four times. There was major confusion here on page 14 with the camber adjustment rod. It shows to identical contructions and then a (!) to show you that they are different. The picture does not agree with the notation. I ended up making everthing the same.
Connect linkages to diff/shock thingy.
Check out the cool dog bones.
Two identical parts here. Both have a diff, shock tower, linkage and dog bones.
Next step is to construct the brake and the slip clutch to the prebuilt transmission. I kinda wish the tranny wasn't prebuilt. I ended up taking it apart anyway because something seemed clunky inside... didn't find anything. Also, the two black screws on page 23 (step 26) in the manual are actually silver and longer.
One very confusing thing about the brake is that it rubs metal against metal. In this pic you can see two round brake discs rubbing against two pinkish pads. But between the two discs you see another metal piece??? The discs rotate and the piece in the middle does not. Is this right?
Build the servo housing. I don't have servos yet. I'm open to recommendations. Please!
Oh god o god o god the moment I've been waiting for. Here you can see everything built so far put together
. Front and rear diffs, shock towers, suspension linkage, axels, drive shafts, brake, awesome aluminium chassis. THIS THING IS SO COOL I can't WAITTTT!!!!
Ok. There you have it. That is day one. Please tell me what I screwed up. I already know I need to rebuild certain parts with the thread lock sauce. When do I put grease/oil into the transmission? Is the main clutch inside the transmission or have I not gotten to that part yet? I can make the brake work by rotating the brake piston linkage thingy but I don't know about that metal on metal. Is that right? What servos and radio gear should I get? I want good stuff but not gimicky. Is my life going to suck when I try to make the engine work without experience?
As you can see I'm mostly questions! Sorry about that =). I really love RC though, hopefully I can be helpful to someone else in the future.
This is the end of day one. Tommorow is another big day. See you then.
DAY ONE
