Amoeba
Hey gang,
So I picked up a Savage 25 from TacRacing (hey Tac! Sweet rig, thanks!) and it's a powerhouse. However, I'm having one issue that I'm curious about.
The L-shaped part attached to the chassis that the Y-throttle linkage screws into is flexing. Every time I'm hitting the throttle the linkage bends inwards. This is making it difficult to really fine-tune the carb action and get a reliable response (or even get to WOT)... especially with the carb return spring on. If I remove the spring I get a little better action but still am not getting WOT. Plus I'd prefer to have a return spring for peace of mind
The Savage 25 manual lists it as a piece of part 85058 (can also be 85051 depending on your manual version or if comparing Savage X parts list).
Are there any hop-ups to a metal or stronger plastic L-piece for the Y-post to bolt into to remove flexing on-throttle? I'm guessing that the plastic has fatigued from usage (even with the support ridge) and is flexing way more than it should. If there aren't hop-ups or mod tricks, how much flex would/should I expect on a replacement part?
Click to enlarge pics & see circled part
