WilliamM
Been enjoying my 1/8th scale Kyosho Inferno Neo Race Spec RTR nitro buggy for almost a year now and have decided to upgrade my servos. I want to go with two HV servos, probably savox for the steering and throttle. This desire has led to a whole host of questions for which I need your help (my understanding of electricity is pretty limited):
1. What is the amp draw of a typical HV servo? (and for that matter what is an amp?)
2. I am having difficulty finding an RX battery that will fit in my battery box. One that I think will work is the Venom 5C 2S 2100mah 7.4V LiPO. From what I have read this battery will put out a consistent 10.5 amps, will this be enough to power two HV servos?
3. Is a BEC the same as a voltage regulator and do I need one?
4. My LHS recommended the Castle Creations BEC, is has a maximum of 10amps, will this provide enough power for the two HV servos?
5. The Castle Creations BEC does not have a voltage cutoff, how do I protect my RX LiPO battery from over discharge?
6. Does anyone know of a BEC/voltage cutoff combo unit, or is there a separate voltage cutoff unit and would I install it between the RX battery and the BEC?
7. I just purchased a Kyosho starter box, and was planning to power it with LiPO batteries. I see in this forum people are recommending a 4S LiPO in the starter box, so same series of questions. Do I need a BEC and voltage cutoff? And does anyone have a recommendation?
I am going to replace the stock RX/TX with my Spectrum DX3, so the RX will be able to handle the 7.4V power.
Thanks, Bill
Thanks, Bill
