RS4 3 evo parts weights
Spyke_696
RCTalk Qualifier
kittanning
i know so many ppl love to know the weights of parts and I'm one of them so last night i did a tear down on my new never run rs4 3 evo and weighed everything so here ill post full weights of everything..
sorry if the parts are scattered and seem to be out of place of alike parts
note i did this in weights using Grams..
receiver lid- 12.3 / screws- 1.2
carrying handle 11.4/ screws- 1.6
Foam bumper 6.7
each rear body post with the end cap and 1 body pin-1.7 /screw- .6
1 stock body clip- .4
stock muffler with rubber boot- 74.
battery lid- 14.5 / pins- .8
intake- 14.5
fuel hoses- 4.2
fuel tank- 32.6 /screws & orings- 1.6
rear fuel tank mount- 3.1 /screws- 1.
exhaust mount- .8 /screws- 1.2
rear body post mount- 3.6 /screws- 1.0
battery pack- 10.2 /with batteries- 99.0
front body post with cap and 1 clip- 2.6 /screw- .4
front upper bumper-3.1 /screws- 1.4
front lower bumper- 10.5 /screw- .6
stock wheel and tire- 29. /lug nut- 1.3
steering servo with horn- 44.4 /tirod- 1.9 /screws- 3.1
break and thr servo with horn- 45.9 /thr rod-.3 screws 3.1
break rod- 2.2
battery switch- 8.
receiver- 6.8
servo battery &reseaver housing- 56.6
exhaust header- 14.3 /screws 3.
engine with clutch,bell,carb,1way bearing,back plate,glow plug-321.2 /screws- 1.8
roto start- 33.5 /screws- 2.1
full tranny assembly-112.2 /screws- 4.5
rear drive shaft- 4.7
front drive shaft- 5.2
chassis- 185.2
1 plastic steering tirod- 1.2
steering horn right- 3.2 /steering horn left-5.3 /screw- 1.3
center steering rod- 1.5
rear battery box to diff brace- 3.5 /screws- 1.8
1 shock- 12.3 / shock with big spacer- 12.8
rear bumper(diff base)-8.8 /screws-2.9
rear top rod- 1.1
rear a arm- 9.8 / screws- 4.4
alum a arm end cap (rear)- 2.1
wheel hub- .5
wheel spindle- 6.4
rear what ever the name of the ting is with the bearing and holds the spindle that with the bearing- 7.9
rear axle- 4.8
rear shock tower -10.3 /screws- 2.8
rear diff -83.5
front diff- 83.5
front diff base- 6.3 /screws 2.9
front shock tower-7.3 /screws- 2.9
front alum a arm end cap- 1.8
front diff support (also holds front side of fuel tank)- 7.6 /screws- 2.7
front a arm- 8.8 /screws- 3.9
front axel-4.8
front what ever the name of the ting is with the bearing and holds the spindle that with the bearing- 7.1 /screws-1.7
front pivit joint for turning- 5.7
It's always a good ideal to tear down a rtr just to make sure everything is put together properly. I myslef wouldn't have done what you've done but I would've torn it down a little.
Ya I didn't want to do a full tear down just cause I well wanted to get into breaking it in and yes I found a few parts I felt were not tight enough
