RPM - Revo Axle Carriers & Oversized Bearings
MyJeep
New stuff for Revo.
(Includes oversized bearings, carriers, & setscrews)
Blue Revo Axle CarriersRPM axle carriers for the Traxxas Revo have been painstakingly redesigned to improve the durability, strength, and reliability of these much-abused parts. Check out this laundry list of features built into each set of RPM Revo carriers:
Axle Carriers:
Stock replacement – no modifications are needed to bolt them in.
Larger bearing bores accept RPM oversized bearings.
Included in each kit are two 15mm bearings and two 21mm bearings.
The wall thickness around the pillow-balls has been increased by 40% - eliminating split walls!
More than 20% more material supports the pillow-balls, preventing them from pulling through.
Redesigned reinforcing rib supporting the tie rod mount.
Redesigned boot lock tabs making removal of the silicone boots easier.
Press-fit bearings in the carrier means reduced movement of the axle in the carrier.
Oversized Bearings:
Outer bearings are 6x15x5mm (stock is 6x12x4mm).
Inner bearings are 12x21x5mm (stock is 12x18x4mm).
Wider bearings create an additional 2mm of contact with the axle for smoother, longer running performance.Stock vs. RPM Bearing Comparison
3mm. larger bearings have balls a full 33% larger than stock!
The load ratings of RPM oversized bearings are double that of stock bearings and more than triple the fatigue rating of stock bearings as well!
Pillow-Ball Setscrews:
Two-piece design uses aluminum and Delrin for the ultimate in holding power under extreme situations.
Our aluminum setscrews reduce movement of the pillow-balls in the carrier.
Our Delrin bushing caps have more than twice the contact area on the pillow-ball, keeping the pillow-balls locked in place at all times.
RPM Revo axle carriers are sold with 1 left and 1 right axle carrier, 2 outer 15mm bearings, 2 inner 21mm bearings, 4 aluminum setscrews, 4 Delrin bushing capsBlack Revo Axle Carriers, and detailed instructions to help install them on your truck. Replacement bearing sets (#80570) come with 2 inner 21mm bearings & 2 outer 15mm bearings.
Tech Note: Due to increased material to support the pillow balls from pulling through the carrier, RPM Revo Axle Carriers will not work in conjunction with 120-LT Long Travel rockers (Traxxas #5356).
80570 Revo Replacement Oversized Bearing Set
80581 Revo Axle Carriers & Bearings - Dyeable White
80582 Revo Axle Carriers & Bearings - Black
80585 Revo Axle Carriers & Bearings - Blue
Suggested Retail
Axle Carriers, Bearings, & Setscrews - $34.95 / pair
Replacement Bearing Kit - $18.95 / set
Source: http://rpmrcproducts.com
dang i just bought a new set on ebay
i may have to check into these anyway
Flippin' Sweet! I heard about these a while back and couldn't find out anything more about them. Then heard RPM really had nothing more planned. And now hee they are. I know what I'm getting for xmas!!!! Now I just have to find 'em.
Deleted for my lack of meaning and detail. Sorry for the confusion.
I don't think its a matter of copying.
Did RD copy the design from the original RPM T-Maxx setup for the Revo? If you think about it, its only logical to bump up the bearing size and beef the carriers.
Out of the two, I would get the RPM. I'm not a fan of Aluminum for the suspensions of a MT. Ill be getting a set of 4 sooner then later.
I wouldn't call making something out of a plastic copying an aluminum product. Several aftermarket mans make larger bearings for carriers.
Ok well i guess copying was not exactly what i was looking for, it is just funny to me how RPM came out with theirs right after RD released his. I am not trying to bash either of them, both make great products no doubt! Guess I should have worded myself differently.
I knew it would be a matter of time before RPM made the axle carriers for the revo... I guess i can wait a little longer before i get a revo... maybe more good stuff will come out... 8-P
I'm not sure if you realize how long it take to do the R&D as well as put together a manufacturing run and packaging on top of that get it all pushed through the distribution chain..
I don't think either of them copied the other. I believe they both decided to make a part and did it.
Lessen said:
wow, 21mm bearings on the inside huh?.?. I wonder how many arms and legs the're gonna want to replace those? heh..
Replacement bearing kit is $18.95 MSRP.
On the other issue, I want to say it was almost a year ago I heard about RPM coming out with axle carriers. RD's are nice, but the aluminum is probably too heavy for my wants. And they are a little salty.
I do realize and agree!
OK
