First off, I want to say hey to everyone and thank you all for the helpful information that is held within this forum. I have been lurking for a few days, since I just got my Revo last weekend.
Anyway, my problem is my Revo overheats plain and simple. It overheats set to the factory settings for 4 out for the HSN and the LSN flush with the sides. I followed the break-in spot on, did everything they said in the DVD and everything. When i run it set to factory specs for the needles, it will get up past 300 with the body off. I live in Memphis, and its about 90 degrees outside right now. I broke it in with the Traxxas Top Fuel 20% and thats what I have been using since, and I've put probably 8-10 tanks through it. I have the Emissitivty set spot on on my temp gun, so thats not the problem...i'm just lost here :shrug:
I talked to my LHS and they said that I might want to try a motorsaver filter, or get brave and snag an ACNCM Giant head for the 2.5R.
I thought that maybe with the body off the flow wasn't concentrated enough, so i cut out half the windshield and the driver's side window to "Ram air" the air past the cooling fins, no luck.
To tune it so it runs in range (220-240) it has basically no power, and bogs like crazy, i tuned it and tuned it, changing just 1 thing at a time and no luck. I was thinking that this thing would have no problem yankin the front wheels off the ground if desired
I messed with the slipper clutch too, and from what I can tell its set alright...how tight should it be? I can stick a allen wrench in that hole and turn the spur gear by hand it it slips with not too much force...is this too tight?
Now the hobby shop where i bought it thinking that something might be wrong with the motor and I should bring it in and they will check it out, if they can't fix it they will swap it.
Sorry to be long winded, I just wanted to give the full story. So heres the question I guess, have i been doing anything wrong? It makes me feel stupid that I have done everything I can think of to remedy this problem, read lots of posts on here and so forth....and still can't get it beat. :arrr:
any help or input on this would be very appreciated!
