Usually ,if an engine is running badly ,an any carb adjustments wont solve the issue ,than something else is wrong!
It could be bad fuel ,bad plug ,leaky head or carb seal ,bad or plugged fuel lines or filter ,the pressure line from the
muffler to the tank is one of the most important parts of the engine ,an the seal on the fuel tank ,if that pressure tube
is restricted any way or if the tank has a pressure leak ,the engine will never run right ,an you will never be able to tune
the engine!
Always keep those things in check ,to check pressure in the tank is simple ,just blow into the pressure tube by mouth ,
an pinch off the fuel line tube to the carb ,if pressure holds under pressure ,then you are good ,if it dont ,then the lid
seal or fuel line or nipple is bad!
Also ,make sure that the muffler itself is pushing the pressure into the line an not restricted!....
