Removing tires
TaterX
RCNT Talkaholic
Perry, FL
Bashing
I know you can bake or boil the tires and some use acetone but what I'm wanting to know is will both the tire and rim be ok. I bought a set of Losi Claws from a buddy for a spare set of tires for my xl but one of them is glued opposite the rest and I can't stand it. I just want to turn it around. Thanks for any help
Phins Fan
Hardcore RCNT User
Keeping warm in a fat roll somewhere.
Bashing
The acetone trick wont work. Not only does it eat the inner foams but your rubber absorbs some of it and the tire becomes expaned and mushy of sorts. I've tried boiling but didnt have much success with that either as I ripped the sidewall trying to break the bead loose. Havent baked yet so I can't say. Good luck
HPI-Killer
Axial Axle Twisting Guru
Northern Utah
Bashing
I baked my wheels/tires on my Axial wraith to wieght the wheels down, works great but make sure you use an oven mit or rag, s**t is HOT!
TaterX
RCNT Talkaholic
Perry, FL
Bashing
Thanks for replying so quick. I just hate to have 1 out of 3 facing a different direction.
I'm confused. When you say "wieght the wheels down" are you trying to make them heavier? I just want to get a 1 tire off a wheel spin the tire around and re glue it.
Snook Man
Hardcore RCNT User
Sugar Hill Ga
Bashing, Racing
The boiling methods works well and its best to let the tire/wheel cool after boiling. The glue becomes very brittle after it cools and the tire usually pops of the bead easier.
Do wear gloves…
TaterX
RCNT Talkaholic
Perry, FL
Bashing
Thanks for everyone's reply's. No question left unanswered. lol Guess ill put a good boil on the claw tonight and see if i can pop it off and get it in the same direction as the other three tire.
TaterX
RCNT Talkaholic
Perry, FL
Bashing
Do wear gloves…
The boil worked good and i lost very little rubber on the rim. Pulled it, flipped it, re glued it. Never wanna be the guy with 1 tire facing the wrong way. So thanks for the advice!:D
jose.28
the friendly guy
orlando fl
Bashing
And a year later i reply lol. I've boiled alot of tires and I've saved about 3 tires and the rest broke.
I let them boil for about 30 to 45 min. But they do become brittle. (Glue)
Rolex
Hoof Hearted
Staff member
Military Veteran
In my recliner
Bashing, Flying
If he's been boiling them since his last post, they should come off pretty easy. :D
Alexander_0_1
"Roads, where we're going we don't need roads"
Frog Lake A.B Canada
Bashing
If your baking your tires or any r/c tire that stick out past the rim, try and find a piece of circular metal that will make contact with the entire edge of the rim, then throw it in the oven...about5-10 mins (on a baking sheet), check frequently...I went down to a local fabrication shop and asked them to cut me some steel disks, I brought them home. Welded a small block of steel just so the tire wouldn't touch the baking sheet
Create an account or login to comment
You must be a member in order to leave a comment
Create account
Create an account on our community. It's easy!
Log in
Already have an account? Log in here.
Thread starter Similar threads Forum Replies Date
BamaFan Removing tires from wheel? Stadium Trucks 6
G Removing Tires fom the Rims Traxxas T-Maxx 2
monsterman Removing Tires From Alumium Rims Nitro RC 9
B removing tires. Nitro RC 1
J removing tires from glued rims? Stadium Trucks 2
J removing tires from rims??? Traxxas T-Maxx 14
A removing tires from rims? Nitro RC 31
E Need help removing a collar Nitro RC 2
BurningRain Removing the sleeve and piston HPI G3.0 Nitro RC 9
sur3fir3 Help removing Chassis brace Team Losi LST 7
A removing reverse servo Traxxas T-Maxx 9
J removing a stripped hex On-road and Rally Cars 10
HSPGuy2190 removing fly wheel Nitro RC 8
laton7 removing fly wheel Nitro RC 6
laton7 removing a rounded screw Electric RC 8
F Removing/swapping steering servo . How to? HPI Savage 2
M removing the exhaust pipe for more power Nitro RC 18
D tips for removing the front and rear bearing on picco .26? Nitro RC 6
R DTX-18 - issue removing crankshaft PLEASE help? Chassis & Drivetrain 1
HPI-Killer Removing Painted Over Chrome Wheels Paint & Body 6
Fuel Crazy Removing threaded pinion gears Nitro RC 0
O Removing Clutch Buggy and Truggy 1
S removing savage x4.6 lower suspention arm HPI Savage 4
Rolex Removing liquid mask Paint & Body 20
B removing clutch bell Traxxas T-Maxx 8
D LRP Z.28R Help removing piston sleeve!! Nitro RC 7
I Removing paint Traxxas Revo 8
Jmacca Removing Paint? Paint & Body 1
Jmacca Removing paint? Paint & Body 9
darkslayor24 removing the brake pad on a rc10gt Nitro RC 3
O CD Scratch Removing Service. General Chaos 8
L removing cb screw HPI Savage 7
E Removing all the purple off my rs4 Nitro RC 11
D having problem removing..... Chassis & Drivetrain 4
O Removing the Sleeve. Chassis & Drivetrain 20
N Removing the Clutch Bell! Nitro RC 9
T Removing the opti drive? Traxxas T-Maxx 4
K removing EZ start motor please help revo Traxxas Revo 17
Lessen Removing Engine Bearings... Chassis & Drivetrain 6
N removing fuel before storage Nitro RC 11
D trouble removing sleeve from block Chassis & Drivetrain 3
R removing reverse gear. need nput Traxxas Revo 4
S removing carb on new os18tm??? Nitro RC 11
digger removing paint RC Aircraft 0
H Removing pins from output yokes? Traxxas T-Maxx 12
dannyd removing engine Nitro RC 30
R Removing Chrome from rims? Nitro RC 2
R Removing powder coat?? Nitro RC 8
R Removing old paint and painting again... Paint & Body 2
M Removing old loctite. Nitro RC 6
