pugs2300
ok guys...ill start at the begining...my buddy had the losi insane motor in his MRC all the other electronics are stock....he ran it for maybe a total of 20-30 minutes and decided he was gonna take it off and do a water break in to it...so we took the electronics off and started the break in and in about 5 minutes we noticed the esc was getting pretty warm so we stopped....a huge amount of crude had been flushed from the motor so at that point we also decided to stop the break in and go with what we had....we let the esc cool down and the motor dry a few minutes and before we reinstalled everything we decided to test and make sure everything was ok and this is where the problem presented itself...
as soon as we tried it we noticed the motor would go fine in revers but no forward...so we reversed the channel and it had forward and no reverse...at this point i was thinking it was the radio so i hooked up my rx (which i had used the night before and it worked perfectly) and got the same results...so not being sure what the problem was i decided to start switching components to see if i could figure out the problem....we had two radios, two esc's, and three motors...no matter what combination we hooked this stuff up we got the same results...we could only go in one direction....even using all my electronics that worked perfectly when we removed them a few weeks earlier we still had the same issue...so I'm starting to think i am doing something wrong....i don't see how all of this stuff could screw up in the same way at the same time randomly like that...I'm really confused and need some opinions....at this point i don't even know what to do to diagnose the problem....help me out guys...
