My first guesses would be that you're running lean or no venting in the body. But you already covered that. Just to be sure, you're running the HSN at around 2 1/2 turns, and the LSN I guess is supposed to be 1-2 turns. I've never been able to really get a good idea on an exact setting.
But you already covered that. So my next thought would be to ask what kind of fuel you're running and how much oil it has. And given all else, I would lean most toward an air leak. I would start to check your fuel tubing, carb seat, backplate, head, glowplug exhaust, and pressure line to see if there is any leaking. That can cause your engine to over heat and run irratically. So start there..
