RC10GT replacemnt pull start needed
Badsneaker
RCNT Talkaholic
Portsmouth
I need a replacement pull starter for the .15 engine in my RC10GT. I changed my starter box to start my buggy so I can't use it on the RC10 anymore unless I take the back wheels off.
I checked A/E and Tower, I can't seem to find the replacement kit. The pullstart cover reads Team Associated AE nitro on it. The RC10 is the kit that covers numbers 7050, 7051, 7060, 7061, 7067, 68, and 91. Made in 2002.
Can someone help me with a part number?
Thanks
HeartBreak
RCNT VIP
Anderson
Well, the easiest way to find the pullstart is not by kit number; altho the information is handy. It helps chase down exactly which engine you have.
Going to Tower and popping in "AE 15" into their search, then clicking on one of the parts for the AE 15 (the carb retainer), followed by going to Parts Usage and then the engine listed, brings up these:
For the blue chassis:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXAYY7&P=PU
Here is a complete parts list:
http://www2.towerhobbies.com/cgi-bin/wti0005p?&I=ASCG2900&P=PU
Hope that helps!
HeartBreak
RCNT VIP
Anderson
No problem man. Towers' search engine isn't all that bad, if you search by part number. It usually snaps it right up.
Badsneaker
RCNT Talkaholic
Portsmouth
Hey Heartbreak do you know if this comes with the bearing? Maybe I should call Tower and ask them.
Badsneaker
RCNT Talkaholic
Portsmouth
Damn that sucks. OK thanks for the heads up. So I need the pullstart and the bearing. Anything else?
Thanks guys!
HeartBreak
RCNT VIP
Anderson
The pullstarts rarely come with the one-way bearing. You can, however, get the pullstart bundled with the backplate and starter shaft. I would recommend replacing the starting shaft as well, as a precaution.
Badsneaker
RCNT Talkaholic
Portsmouth
The starter shaft looks OK. There is a foam seal on it. I pulled the old pullstart off to find it was just reinstalled to protect from dirt. No bearing. I have a .15 pullstart I got with the MT I received from 1500valk but the bearing I had was slightly in my box was slightly too small. Upon initial install it did turn the ole RC10 engine over though. I will try the pullstart and bearing from Tower.
Dcoker6
I'm in need of a pull starter but everything I'm finding is discontinued. Any help?
D3MON
Hardcore RCNT User
Missoula MT
ebay is going to be the best bet to find one i believe, there is always the option to get a Sullivan Tiger Drive and use a drill for starting
