OS4ever
So, my bearings went out in my clutch bell. I put in new bearings and replaced the clutch too, it was shot. After I get everything back together all the truck does is rev up and barely move. I put one shim behind the bearing then clutch bell then other bearing then e clip. I'm thinking i might have to take the shim out, because the last one didnt have a shim but there was play on the end of the shaft causing the bearing to halfway seat in the clutch bell.
any suggestions?
any suggestions?
