Is the "neck" of the carburetor on a nitro engine good for mounting a pulse outlet? It is to be used with a Walbro carburettor.
Are you talking about a gas carb that has the fuel pump diaphragm in it?
Yes.
EDIT: I might not have explained myself correctly. I'm talking about the neck of the engine's intake, the one in which you'd slide the carby. Let me worry about mounting the Walbro, I just need to know if I can get pulse from the aforementioned position on the engine.
I was afraid you'd be right . Doesn't look like there's any suction off the carb.
My carb doesn't have a primer, instead it has a built-in pump pulse inlet nipple, which is why I wanted to use this particular one.
Any other way I can generate pulses for the carb? If not, I think I'll go with an electric pump-or simply place the fuel tank higher than the carb. Ideas are welcome (and desperately needed).
So fuel builds up pressure by itself when the engine's running? This applies to gasoline or nitro as well?
I remember that when my old GX15 wouldn't prime, I would cover the carburetor and crank it. The fuel would rush to the carburetor blinding fast when I did that.
Alright. Here's the plan.
My carb also has two frontal ports above and below the throttle valve, probably used to bring in the carb's pressure to the pump, assuming the optional pulse inlet isn't used. I'm gonna make sure the mount is big enough that those ports are exposed to the crank, and hope that the engine's pressure is enough to man the pump.
If that don't work...I'll sort it out .
Thanks for the help!
Hehe, well I appreciate your help very much, but I'm sure it would be more than worth the hassle to ship a few carburetors all the way to Southeastern Europe. I've got a few old chainsaws in the back, so maybe I'll pay them a long-awaited visit if I'll have to get a new carb.I have a box of carb.'s ,I will take pics of them an show you the different types I have!
You are more than welcome to have a few of them for your experiment for free ,but
you will have to pay the small SH. fee through pay pal!...
I'm close to finishing the carb mount now, looks pretty good so far. I'll keep posting my progress here, and hopefully I'll have the engine burning gas until Christmas!
Ok no problem ,didn't know that you were across the drink!...
Years ago when I started my own yard care business ,I had to learn real quick how to repair an actually
build my own lawn equipment!
I use to go down to the local small engine repair shop an the owner use to sell me his old junk that
people left an didn't pick up ,yea ,like a small engine junk yard ,that's where I bought a lot of stuff
an accumulated a lot of parts ,bought a lawnmower there for 20 bucks 20 yrs ago ,an I still use it today!
Since about 4 yrs ago ,he closed up shop an retired ,I sure do miss him & his junk yard!
Now everyone comes to me ,because there is no other repairmen for small engines
with in 25 miles!....
So ,if you have a repair shop like that ,ask them if they got a junk pile out back!..
