problems!
unknown123
RCTalk Champion
canada
hi I'm really mad.I'm sure this has happend to someone.The problem in that when i try to start my nitro rc buggy it starts then dies out when i take off the glow igniter.I have my factory settings.The buggy I'm using is a kyosho inferno us sports with a GXR28 engine.So can ANY ONE HELP!!!!!!!!!!!!!!:(
no mine does this not a big problem leave your glow plug in and bild up the revs slowly not too fast or will stall once its runing and reving take glow plug stick out then your off hope this helps.
+1 on tuning,
Have u tuned the engine since break in ?? if not, try tuning it according to the manual recommendations
Have u ever changed the glow plug since break in ? If not REPLACE IT
Have u got a damaged exhaust seal (this CAN cause stalling).
Is you carb slider set with the correct gap ? (adjusting the idle speed screw will adjust the carb gap)
When you take the ignitor off and it dies, the glow plug is always the main suspect. There's NO good reason not to change it. If the problem persists, move on to tuning until you can keep it running, let it warm up, and tune for performance.
i will try it soon i can't today because
the stores are closed =(
