Ok the car is a NTC3, kit version, with standard gears and standard clutch mated to an OS .15 CV-R (nonpull).
The situation:
Was out bashing today since it's gonna rain for the rest of the week. Everything was going well. Just finished retuning, temps around 230 F.
After a few high speed passes, the revs would pick up but no movement. After 2-3 short guns of the throttle, revs would drop and clutch would engage normally. Ok thought it was a fluke. Tried to replicate the same problem, but nothing happened. After a few minutes, hit a bump ... car bounced and then it happened again. Can it be the clutch? All gears are fine, no missing teeth or small pebbles in teeth.
The clutch has barely over a gallon of run time. It was originally on my .12 CV-RX (about 3/4 of a gallon) then switched everything as is on to my .15 CV-R.
I am thinking that it may be as simple as a clitch spring or maybe it's the clutch shoes itself or a glaze on my clutchbell. Should I just replace the whole clutch assembly since it might be time?
Has anyone tried using aluminum shoes on their NTC3? Anyone ever do a 3 shoe conversion on their NTC3, and what type/manucaturer?
The situation:
