please help losi LST super truck problems
blurman18
my fist problem is i have to open the throttle all the way to get the truck to start rolling then when i get it rolling i have to keep on the gas or it will stop and ill have to open the throttle all the way to get it moving again. the second problem is that the breaks do not work at all i can't stop.
+1, sounds like you're rich.
Sounds like you need to adjust the linkage and/or radio settings..
Is this new or used?
IF new was it broke in?
If used has it been sitting for a long time?
what engine?
did you adjust the carb back to factory settings and start from there?
tell us more information
it has been sitting for a long time. and the engine is a mach .26 engine it is used, and its a really rich carb setting.
what engine?
