JoeMAXX
Gone - bye bye.
I know this has been mentioned many times in the past.
It was 55 degrees outside today and I had just bought a new HPI Trophy 4.6 Truggy. So I wanted to perform the engine breakin so in the spring I can finish the break in process. I carried enough fuel today to get thru the 4th tank of fuel I will perform the 5th tank in the spring. The hottest my engine got today was about 160 degrees.
Below 60 degrees outside you need to keep the engine a bit warmer for proper breakin and seating of the parts.
Wrapping no more then the top half of the fins of the engine with foil will help to reduce effects of cold weather break in and this is my suggested method. It was warm enough today that I did not need to wrap the engine.
Wrapping the bottom half of the fins on the engine might get your engine too hot and may not provide enough cooling to the areas that require it the most.
I have multiple different Engines manuactures installed in my various R/Cs and each seem to have a slightly different break in procedure then some have also changed it over the years. I am old school and have been running nitro engines since 1999 than like the old tried and true method of a 5 tank breakin procedure.
O.S Engines used to post a similar procedure years ago now they suggest you can break in an engine with just 3 tanks. They also suggest using a High Oil Content fuel these days of least 18% or higher during engine break in.
NovaRossi suggests an 8 Tank break in procedure. They also suggest using a High Oil Content fuel during Break in. These are high compression engines so I see why they suggest it.
Picco also suggests using a High Oil Content Fuel during break in to reduce wear on the parts and keep the engine cooler.
Traxxas has always suggested a 5 Tank procedure for their engines. Traxxas top fuel is a high oil content fuel mix. I used the 20% Nitro for my engine break in today.
HPI Racing blew me away with them suggesting running the first tank of fuel with the tires off the ground and only a 3 tank breakin procedure. This is the worst thing you can do to your new engine :whhooo:
So in conclusion if I am ever asked what is the best break in procedure I will suggest a 5 tank gradual procedure leaning the fuel mixture by 1/8 of a turn on each tank of fuel with slow to meduim speeds thru the first 4 tanks and do not sustain full throttle on the 5th tank for long periods of time until you are on your 6 tank of fuel. By the 7th tank your engine is race ready.
