ok when i did a leak test .It leaked out from the cam bearing is this normal or do i need to replace it. its a 8.0 running hot and chasing for a good tune.could this be the problem?
That depends on how bad it's leaking. What leak test did you do? Have you found any other leaks? Does the truck have a good air-tight exhaust and fuel system?
