Outcast 6s EXB, E clip problem
Savantv13
I'm constantly loosking E-Clip - 3.2mm (#ARA710006) durring rides. It's jumping out of it's designated place what's causing another problems like broken gearings on my motor. Do you have any interesting solution for that problem? Or should I buy 50 pack of them?
I used aircraft safety wire once you spin the loop closed its not coming off. it might be a 30$ start but well worth it in the end. get correct size then safety wire pliers amazon is the place...I got 6 different sets of pliers you dont need the 100$ set.
You need good e-clips. The cheap ones are really not springy at all (chinesium steel). Make sure if you buy them they are made in USA.
here.
if the military uses it, it works.
Lol, I made a lot of crazy stuff for them too. Like one time... while making some perfectly faked RPG's of a foreign design, with a certain agency's oversight... well... better not lol. Man, I really miss machining cool stuff.
