one way bearing cleaning
exmark93
Livingston County, MI
I've look for how to clean this thing everywhere on the site but cannot find it. can i use isopropyl alcohol to clean my OWB if not what else can i use that would be easy to get
you mean like just dousing it in WD40??
yes ... spray it on the inside ..you should see the dirt come out ..its also good to spin it a bit on a shaft to make sure the bearings get cleaned on all sides ......then twist a rag and put it in the hole to wipe the bearings ...hope that helps
hmmm sounds crazy cause wd40 is a lubricant but ok, ill give it a try!
