Originally posted by imnotsure
i tried to convince him, but he was dead set on putting a new carb on there, but oh well, it all worked out.
The main problem was the metal gaskets. Before I started in on the carb project, I pulled both needles and found the there was no torn O-ring on the HSN, or crap in any part of the HSN side of the carb. The o-ring was in perfect condition and seated properly. But every time I ran the thing, my outside filter on the motor saver would be soping wet with raw fuel at the HSN, it would also be on the side of the carb. I can see the point of using teflon pipe wrap, or a silicone based sealer on that area, but why bother if the mid range mix is so off that it pisses me off so bad that I don't want to run the truck? I know, change the LSN needle. Well, it wasn't included with my engine, or even mentioned in the included docs. Thanks to imnotsure, I learned about the little needle mixup at ofna/picco (mostly picco IMO since my Hyper 8 has been one of the best engines I've ever owned). So, therein lies the quandry. Spend another $10 on a part that should not have to be replaced, or do what I like to do and screw with it just to see what happens. Well, I took the second option since 1) I had the carb, 2) I wanted to run my truck, and 3) the 21BB carb is a crapton better than the picco carb (IMO) I'll probably end up getting the black needle and putting the stock carb back on, but it'll be at my convienence and not depended on the postman. If I had the proper tooling, I'd probably learn to make my own engines, or do some trick poop to the ones I have, but I don't, so I do what I can with what I have. I never said, do this to anyones engine, I just thought it would be cool.
One of my engine idols was a guy named Mike McKormic. He flew pattern and loved to blueprint his YS 1.20's. He was doing some poop to those mills that was unbelievable. Scarry power. There's a guy here in town that ports .21's. I've seen his work, and seen them run, and it's scarry. This was my first attempt at doing the same, and you gotta start somewhere.
Sorry if I sound hostile, I'm in the middle of watching LOTR2 and really got my hate on for some orcs.
Whitt...
