I recently purchased a slightly used Revo 3.3 with a blown motor. I've purchased a new replacement motor.I went with the picco.26 max jl red dot.
What other parts do i need to replace to make this work ?
If you are running something like 15/38, TRX's stock clutch will probably be ok . . .
But with the power of the .26 you could gear up a bit - it will pull 17/36 no probs . . .
With the higher gearing the standard TRX clutch shoes will struggle to keep up - you will burn through them in no time flat. . . best to upgrade to a alloy 3 shoe set up.
