New to nitro RC
Sammyl0co13
I have a Traxxas T-Maxx 2.5 on the way I heard the suspension and drive shafts are weak on there I was wondering if you guys could give me any tips on what I should upgrade first to the the suspension and what brands
Welcome to the site. The harder you are, the easier it will break. If you take off full throttle from a stop, spin tires from a slick surface to a hard surface,or land from a jump on the throttle, those will be harder on your driveline.
If it were me, I would buy 4951x drive shafts, 4953 stub axle, and 4982x drive yoke. I would buy those to have spares, if you go through those, then you will need something beefier.
https://traxxas.com/explodedviews/49104-Front-Assembly
For spares, air filter, air filter oil, glow plugs, spare wheel nuts and body clips.
Rpm also makes plastic parts.
https://www.rpmrcproducts.com/shop/?filter_make-model=traxxas,t-maxx-e-maxx
Thanks đź‘Ť
How many of each should I get of all that stuff you put do I need to get cuz there are four drive shafts do I have to get four of each of those
I would say
Air filters 5261 comes in a 3 pack.
2 or 3 spur gears, they are under $4 usually.
4951x is pictured as 2 full drive shafts, id say one pack.
4953 stub axles are two in a pack.
The 4928x is also two per pack, but I would get two packs as they are used on all four corners plus on the center drive shafts.
If you have the money and its a long drive, Id go two each that way it gives you time to figure your truck out and not have down time.
Last question last question I want to replace all the servos what size servos do I need for what I have experience with electric RCs I do not have a t Max classic on me it will be here tomorrow
Any regular size servos will fit. I linked some Ecopower ones that are cheap but got great torque and speed. Check them out here. Hope this info serves you well.
I
Replies
20
iamnotsmart
I
SpeedRacer5873
Replies
6
Chubaka
Chubaka
D
Replies
12
tudordewolf
tudordewolf
E
Replies
3
tntpoof
tntpoof
jrduggan88
Replies
4
lilelvis81
lilelvis81
