joshiestevens
RCTalk Racer
Hi. I have just built my stadium force, and I want to go out an break it in now. The thing is I have a problem with the throttle, and it is not to do with the servo arms or anything. I am pretty sure it is to do with the carb.
In the instructions it says that it should be opend to about 1mm when neutral and when pressing the break. If I open the throttle fully and then let go back o the neutral position, it gets slightly jammed to about 2mm open. The only way to get it back to 1mm is to press the break and then let go so it goes back to neutral.
I hope someone can help me out.
Thanks
Josh
Thanks
Josh
