Meldarion
RCNT Member
Ok so i have had a look around at some of the different cars, and though i did like the sound of the traxxas t-max, i can only find the 3.3 which costs like £330, so i am going to get the schumacher rascall, which from what i have read, appears to me quite good (Please let me know, if you know of any major issues with this car!)
Ok so the main issue for me now is going to be how i break in/tune the engine. I have spent a lot of time looking around the website at different break in methods, and i have seen enough to know that there is no one method that everyone has decided is the best, but i just want to make sure that i am doing the right thing so that i don't completly nacker my engine. I will try and go through it step by step and if you could just let me know if i am making any major mistakes, or suggest any other things, i would greatly appreciate it
1) Check that all the screws in the car are tight, glue the wheels, set the needles to factory settings leaning out the HSN by about a quarter of a turn (Because the factories settings are often overly rich, and from what i have read, you want the engine to be *Slightly rich* for heat cycling)
2) Use a sharpy to mark out BDC (Bottom dead centre) on the flywheel
2) Wrap some tin foil around the cooling head of the engine and then use a hair dryer to warm it up
3) Fill up the tank with fuel (I think the one that i have is 20%), prime the engine
4) Fire up the engine and start running it around, varying throttle, but not going over 1/2 throttle- Aiming to get the engine up to operating temps (200F)
5) After 3 minutes, shut the engine down and allow it to cool, with the piston at bottom dead centre
6) Repeat this process for 15 minutes, shutting down every 3 minutes and allowing it to cool
7) After the first 15 minute block, i will begin to increase the throttling from half, going up to full but not for extended periods of time- Checking that the temp is still around 200F, For 4 minute intervals, allowing it to cool down at the end of each
8) Continue this for a further 20 minutes, and at the end of this it should be pretty much run in
For tuning :
After the engine has been run in i will begin to slowly lean off the high speed needle until there is only a thin stream of smoke coming from the exhaust, and its performance appears to be maxed, i will then richen it off slightly once it reaches this point to ensure maximum life of the car, and good lubrication
Hopefully this doesn't sound too bad, but i just wanted to check it out with you guys before i try it out
Thanks, Meldarion!
For tuning :
Thanks, Meldarion!
