New 3.3 motor and pull start conversion, Help!
jayeddings
Okay i got a new 3.3 traxxas motor for my revo. i found the pull start assembly but i need the the peice that connects the pull start to the crankshaft. Where can i find that? I looked on amain, maybe i missed it?
ummm, usually comes as a kit.... unless your talking about the one way bearing and the shaft that it goes on?
Yeah i need the pull rope and the bearing and shaft and i guess the backplate
So when u got your motor it didn't even come with the backplate? I'll find those part numbers this avo for you unless someone else gets em for u
---------- Post added at 7:58 AM ---------- Previous post was at 7:58 AM ----------
By this avo I mean 9ish hrs
It would be best to check the crancshaft to make sure it has the pin for the starter shaft also.
it doest have a pin, its just flat with the connecting rod, idk what kind of starter i put on it
You may need to buy a new crank. It should have a pin that the rod connects to and then it should poke out a bit more. I'll jump on the Pc soon and get some pics and stuff up. I'll try find all your part numbers you'll need too
Post a pic so we can see exactly what you need...
so, this is what you need from front of motor to back if you want pull start.
crankshaft tra5288
http://www.ebay.com.au/itm/Traxxas-...Radio_Controlled_Vehicles&hash=item3cb1442a21
backplate/shaft/owb tra????(can't find product number)/tra5277/tra5211r
http://www.ebay.com.au/itm/Traxxas-...Control_Parts_Accessories&hash=item4d003e27b2
pullstart tra5170
http://www.ebay.com.au/itm/Traxxas-...Control_Parts_Accessories&hash=item1e6c64dde7
now i havent searched for the cheapest prices etc. but that is generally what you need.
try a main hobbies for these parts.
---------- Post added at 8:39 PM ---------- Previous post was at 8:37 PM ----------
try this guy for parts. iv bought a whole motor from him and he is a great ebay seller... strongly recommend him. parts are brand new
http://www.ebay.com.au/sch/dollarho...&_odkw=&_osacat=0&_trksid=p3911.c0.m270.l1313
---------- Post added at 8:40 PM ---------- Previous post was at 8:39 PM ----------
do not buy a crank like this if you want pullstart
http://www.ebay.com.au/itm/Traxxas-...Control_Parts_Accessories&hash=item43b085e28d
see no extra knob on end.
The crank that you said do not buy, is the one it has. Which why would that be in if you can start it???
The crank without the pin for the starter shaft is for a bump start engine. It uses a solid backplate and the engine is started by turning the flywheel with the starter box.
If you want to use a pull start/ez start or roto start you will need the crank with the pin the starter shaft and the new backplate.
Show me what i need to make the bumpstart work. I will just go that route, thanks guys!
That means u have to carry a big box nearly the size of the car itself. It may be cheaper going pull start still... The bump start requires a battery similar to the ez start and yeh it that's flat ur day is over
How freaking dumb to make something like that!!!!
Bump boxes are mostly used by racers only. Whos engines usually stay running the entire race without worry of stalling and having to carry the box far to restart the rigs.
It also frees up some HP and saves some weight.
do any of you guys know if paypal automatically charges my debit? it says my gross is -$41. i bought parts for the revo last night
if my account goes negative it generally comes back into my account... did you get new crank, back plate etc?
T
Replies
6
J’sCrawler
J’sCrawler
E
Replies
15
Lukedavis
Lukedavis
ccater1026
Replies
1
Nitroman7888##
Nitroman7888##
ccater1026
Replies
15
Nitroman7888##
Nitroman7888##
