yaaay i I got (an) engine...DOESN'T WORK...lol i bought it from lhs and i was taking the stuff off my .15(idk what they are called but there what go on the shaft with the screw on it)(could u tell me what that stuff is plz) Well, I'm guessing you are referring to the collet, the flywheel, the clutch nut, the clutch, clutch bell, bearings and possibly an E-clip.and i was putting them on the .18 and ther rubbed against that carb thing you need to add shims behind the collet so the flywheel doesn't rub the carb (which is not a "carb thing") then the screw that goes on it i couldnt get off so i had to stick a screwdriver down the carb so it wouldnt turn to get the nut off (I'm guessing you cross threaded the clutch nut or something). so tommorrow going to go and bring the .18 back and ask what i need to get it to run. (patience and a look over the OWNERS MANUAL would be my suggestion!) There is nothing wrong with that engine (at least there wasn't) but you haven't taken the time to learn the basic part names of an engine. I'd suggest you at least try taking that initiative to learn a little more.
Didn't you say you have an ALMOST 4 year old RC10GT? How did you get the extra year again? Why did you even put anything foreign in the carb other than fuel? I would recheck the settings on the engine All needles need to be reset to factory, use fresh fuel, a good or new plug and a charged ignitor. From there I want to know where you stand.rc10nitro said:lol..finally someone tells me. i had my gt for 5 years but we moved the second year we got it and most of stuff was in storage for like a year. then when we moved the stuff from storage,i grabbed my rc/car and it wouldnt start so i bought a new glow plug and new tires. then i didnt bother getting a new one cus it was cold out and snowing so i just put the box in our basement and i forgot about it.then like 3 days ago i found it and i rembered the engine didnt work.and i called the lhs about sticking the screwdriver down the carb and he said to take the carb off and see if anything was bent. and the was nothing so my engines good. but now it wont fit on my old mounts.
rc10nitro said:ARE U KIDDING ME!!!! direct drop in my @$$. i spent 45 bucks on other stuff then the motor (new fly wheel,clutch nut,2 collets,engine mount,mip clutch spring)then had to cut this thing off cus the pull start wasn't out far enough.
took me 3 hours to put all together and either my clutch bell doesn't work or I'm missing a spacer so i can't run it. the clutch bell doesn't turn with the fly wheel, thats y i can't run it. i actually getting to know my parts![]()
Only thing you MAY have to do is trim the crankshaft a bit. Otherwise, will drop right in. If it's a pullstart, you'll have to make sure you have the right engine mount.
oooo i get it now. either way i would of have to replaced that stuf any way.
